You guys are so good around here, I figured I would throw another one at you.
I am installing a Cheviot model #5138 tub filler in the vertical wall. I thought I could simply screw it in a 1/2 drop ear elbow with a pex connection and keep on rolling. Well of course it couldn't be that easy.....the tub filler has a 1/2 male threads that are non tapered. How do I fit that on to all these NPT threaded fitting that I have? Is it standard for faucets to be designed this way?
Ultimately I would like for it to 90 degree down and end up to a pex fitting. I am running out of room between the studs because the tub filler arms are 2 1/4 long. But I will try anything. Thanks for you time!
