Tub drain too short
Jayman
Dec 16, 2013
10
I am installing a free standing tub on a concrete slab. Somehow my alignment must have gone astray and the hub on the drain piping is sitting just over 1" too low. Does anyone know of an extension piece that could be used. Thanks for any help you can provide.
This is the hub, the drain screws in from above The hub is approx. 1-1/4" too low.
OK, I understand now.
No, I have never seen an extension for a tub waste.
It appears to me that if you cut the 90 off with a reciprocating saw, then used a diamond blade on a angle grinder to cut out the tile around the pipe a little, then hammer and chisel to break out a little bit of concrete, then you could cut just below the 90 and couple on to the pipe.
