Trying to Remove Bathroom Faucet
LordWilling
Nov 26, 2016
Hello,
I am turning to this form and the professionals for help on this. I am simply trying to remove a 3 hole, 4" bathroom faucet and install a new one. However, I am having a hell of a time figuring out how to remove this from the counter. I've watched countless YouTube videos and thought this would be easy. I disconnected the water lines and was able to pull off one of the handles(as seen in the pics I've included). However, there appears to be some type of plate at the bottom but there is no nut/bolt that I can see that is holding the faucet in place. I can wiggle the faucet from the top a little bit and turn the spout a little as well but I cannot figure out how to simply pull this faucet up from the 3 holes in the counter. I have attached 2 pics. Can anyone give me any type of advice or suggestions as to what I should do next?
Thank you so much in advance!
This is a discontinued MOEN Monticello 4" widespread
Model # T4560CP
you can find it on Moen website under "parts and support" use model # above
if this link does not work PDF manual
