plumbing rookie
Hello folks. So I'm trying to fix a leak for the hot water in the shower. The problem I'm running across is the hole in the fiberglass is just barely big enough for the valve stem wrench to go in and the nut at the base of the stem is a little off-center, so I can't get the wrench on the nut. Am I going to need to trim the fiberglass back or do you guys have another suggestion? If I do need to, how would you suggest as the best way. The only thing I can think of to do is to drill some holes in the fiberglass around the hole, then use some plyers to pop the piece out. Thanks for any help you can offer.
