Hi All,
I own a manufactured home in Maine. The previous owner did a lot of "fixes", which included remodeling a bathroom. We've owned it a year and the whole time, the toilet has wobbled. Recently, my wife has noticed dirtt water leaking from the base at the back.
I pulled the toilet off and everything looked ok. But I noticed he had used a piece of wood to shim the toilet from the back. It looked like 1/8" or 1/4". It fell apart when I took it out.
I noticed that the flange is bolted to the finished floor rather than the sub floor. He had also replaced the flooring with that vinyl plank. That's only 1/8" or 3/16" thick.
I installed one of the green foam rings and bolted the toilet back down. It's still rocking. I had to add a bunch of plastic shims. The toilet is now level, but still rocks. I'd like it to sit flush on the floor.
I feel like the flange sits too high. I also know the floor isn't perfectly level there too. Should the flange be flush with the finished floor? Or did I do something wrong when reinstalling it?
Thanks
Thanks
