I think your right I only see johnny bolt he needs to get some tapcons 1 1/2 or 2 " so that repair flange wont move...Is that flange even secured, or is it just laying on the old flange?
Does the flange sit flush with floor? And the flanges should be secure to floor also if the tank to bowl bolts leak it can make it seem like toilet is leaking from the base
"The new flange sits just above floor level."If it's not your tank to bowl gasket leaking when you flush it then I have had problems with leaking if the flange is too high. ( I can't really tell in the picture how high the flange is above the tile) but to fix the problem In that situation I use a wax ring with no horn and it will let it squish down good. I prefer the wax ring with the horn every other time but it seems to get in the way if there is very little space between toilet and flange.
