Ok, so about a month ago, we started having problems with our toilet not wanting to flush. #1 will usually flush slow but it will flush unless TP was used the flush before. If you use TP and/or go #2, it will either barely flush and won't flush the next time or it wont flush at all. Use of an accordian plunger usually makes it drain fine. This is an on going battle though. Dosn't seem like a normal plug. I also tried one of those pressure balloons. Ran the water for about 5 minutes and it seemed to help a bit but it still dosn't seem like it flushing like it used to. I might add that it appears to me that a small flow of water is coming back in through the drain??? You can see little fragments of TP swirling around in the bottom, Especailly after plungering.
The TP after plungering would indicate a clog to me but dang, I have been plungering and the works like crazy, figured it would have gone down by now.
I don't know what to do next............
If I have to take the damn toilet off then its getting replaced.
Also might add that all the other drains drain fine.
Any help would be good, thanks.
