Doug Lassiter
Needed to replace a toilet flapper for a standard 2" diameter drain. Got a Korky 2", and installed it. It leaked. The plug below the flap was quite small, and would certainly not seal in the 2" drain. Replaced it with a Fluidmaster 2", which had a noticeably larger plug. Works very well. Now, the Fluidmaster has a plastic snap-on bracket, which will break with time, while the Korky is all rubber. So I'm suspecting the Korky would survive longer, but it leaks. If you're replacing the flapper in your toilet, might want to pay some attention to how the plug in the flapper would fit in the drain pipe. These different brands are not equivalent in design.
