thinkgreen216
Recently I've noticed the water level in my bathroom toilet bowl dropping. I'm not sure what the cause is but here's a little background. I recently replaced the toilet in the main bathroom of our home with a new Kohler toilet. It works great and has no problems. The toilet that is having water level issues is the toilet in the master bathroom. The two toilets probably share the same drain I'm guessing because they are only a few feet apart from one another. They're basically divided by an adjoining wall. I have noticed when the new toilet is flushed I can see the water in the other toilet gently slosh back and forth and the water level drops just a little. If the new toilet isn't used, the water level doesn't appear to drop in the other toilet. Another thing to note, I did smell a faint sewage smell the other day but I've only noticed this 2 or three times. Does anyone have any guidance or suggestions to correct this problem?
One more thing to note, the new Kohler toilet claims to be able to flush giant turds (okay, I made up the turd part) but it does advertising the ability to evacuate the toilet bowl quite rapidly (which it does)
I'll also add that this is only a one way problem. The new toilets water level isn't affected by the old toilet being flushed.
Thanks in advance for any help or suggestions to remedy my problem.
