Gentlemen,
I replaced a length of some original galvanized with PEX using a brass 3/4" x 1/2" threaded to barbed adapter. It's developed a small leak that seems to appear in the same spot, regardless of how much I've turned it.
My other fittings in the entire job are doing fine, no leaks (there is of course another threaded connection on the other end of this length of PEX, I also put a ball valve downstream of this connection, tee'd off from the new section of PEX, added a 1/2" x 1/4" angle stop, then it's directly into the fridge from there), and this isn't my first plumbing job. Tightening this connection doesn't seem to be changing anything, and at this point it's as tight as I can get it. Plus I'm afraid of putting too much torque on the crimped PEX connection.
