Thermostatic mixing valve help
Discussion in 'General Plumbing Help' started by dmichel, Dec 11, 2017.
  1. Dec 11, 2017 #1
    dmichel
    dmichel
    dmichel
    Dec 11, 2017
    5
    Hi everyone. Thanks for any help in advance. I moved into my house about a year and everything worked fine. The last couple of days I've been unable to get really hot water in our master bath. The shower, sink, and tub all get warm but not hot. Warm enough to shower but just barely. The hot water tank is fine as the rest of the house has properly hot water. I suspect a thermostatic mixing valve, but the problem is there isn't one in the mechanical room near the tank, and everything else in the house is drywalled so I fear there my be one buried in a wall or under a floor. But this seems stupid and I'd have thought against code. Anybody have any suggestions of what else it could be or where to look if I'm on the right track.
    Cheers
  2. Dec 11, 2017 #2
    Mr_David
    Mr_David
    Mr_David
    Easily Amused Professional
    Jan 12, 2010
    3,868
    930
    Santee,Ca,
    what kind of shower valve do you have. Could be the mixer in that.
    I would repair that first if you can't find a common mixer for the bathroom. Could be cold water is passing through valve even when iy is closed.
  3. Dec 11, 2017 #3
    dmichel
    dmichel
    dmichel
    Dec 11, 2017
    5
    Not sure the brand but it's fairly nice with 2 body sprays Integrated. Is that a common practice with all washroom water supplies going through a shower valve?
  4. Dec 12, 2017 #4
    dmichel
    dmichel
    dmichel
    Dec 11, 2017
    5
    Figured out it's a delta monitor with sprays. I think it has a built in thermostatic mixer but the documentation isn't great.
  5. Dec 12, 2017 #5
    Mr_David
    Mr_David
    Mr_David
    Jan 12, 2010
    3,868
    930
    Santee,Ca,
    Delta Monitors I believe are pressure balanced valves, Not thermostatic.
    There is a difference.
    The water supply to other fixture does not intentionally pass through the mixer valve but on occasion upon failure of inner seal may allow cold/hot to pass through the valve while it is in the closed position. Moen were notorious for this. Delta monitors ?? unknown if they do.
    We used to check for this by shutting off the water supply to water heater.
    if water is crossing over it will be evident when you turn on the hot water at a fixture. Should be getting no water from hot side. If you have a significant flow go listen to each fixture and see if you hear water passing though it.
  6. Mar 13, 2018 #6
    dmichel
    dmichel
    dmichel
    Dec 11, 2017
    5
    Reviving an older thread. I changed out the shower valve in December. The new cartridge fixed the problem. At least for a while. It's been about 3 months and the same problem has returned. I assume the repair cartridge has failed again but after 3 months seems excessively short. Anyone have any insight?
  7. Mar 14, 2018 #7
    ExtraMilePlumbing
    ExtraMilePlumbing
    ExtraMilePlumbing
    Aug 21, 2014
    438
    67
    What’s the water pressure to the house? Also water quality(lot of chlorine)? How old is the water heater ? Do you flush it once a year? It could be a lot of sediment from the water heater clogging up that sensitive cartridge, also repeat the steps mr David suggested(this time it might be another single handle faucet)could also be the quality of cartridge , did you get it from manufacture and grease it up before you installed it
  8. Mar 14, 2018 #8
    dmichel
    dmichel
    dmichel
    Dec 11, 2017
    5
    Water pressure is good but I don't know the psi. We are on a well with a submersible pump. No chlorine and a few year old water heater. Haven't flushed it, maybe that's the next step. I tore down the old cartridge and there was a bit of rust discoloration but nothing obviously clogging the pressure balance valve.
  9. Mar 14, 2018 #9
    ExtraMilePlumbing
    ExtraMilePlumbing
    ExtraMilePlumbing
    Aug 21, 2014
    438
    67
    Just replace the cartridge with a manufacture one , also make sure it’s not another single handle valve crossing over, they sell water gauges in any hardware store
  10. Mar 14, 2018 #10
    Matt30
    Matt30
    Matt30
    Professional Professional
    Jan 17, 2012
    1,924
    756
    Halifax, Nova Scotia
    Long time no see extra mile!
  11. Mar 15, 2018 #11
    ExtraMilePlumbing
    ExtraMilePlumbing
    ExtraMilePlumbing
    Aug 21, 2014
    438
    67
    I know, I’m glad to be back and with more experience to help others, 2 more years till I open my own doors can’t wait.
Share This Page
