rob49
Plumbers came out to replace anode rod, but a pipe had been run directly over where old alum anode as installed and they would have to cut that pipe to get to the old anode. They said they could install anode rod directly into the hot water entry into tank at the top. They removed about a 30 inch long plastic pipe with multiple holes in it, which I assumed was for circulation of the water. I had requested a magnesium anode rod, so they installed what they called a "kit" which, in addition to the mag anode rod, had a couple 6 inch sections of pipe that coupled the anode in tank with the hot water line at top of tank. (This "kit" cost $340 which was about $270 more than a mag anode rod alone. This is before labor). So we have a mag anode rod installed (and the 4-5 year old aluminum rod still in tank). One more thing before asking my question.
After they left and my wife and I showered, we noticed that the hot water in bathroom farthest from the hot water heater in attic was about half as hot as before the plumbers did their work. I called plumber who said that removing plastic rod and installing the mag anode would not have affected the temp of water. (No one had changed the set temp of water at tank).
My questions:
What was the plastic rod with holes in it and its purpose?
Why did temp of water change after the installation of anode rod?
Thanks
My questions:
Thanks
