RobD
Active Member
Hello! I noticed a slight intermittent tapping sound in the garage when the water is running (video attached, you can hear at the 3 second and 8 second mark). I'm assuming this is from the pipe tapping into something? The home was built ten years ago and I never noticed - it likely has done this the whole time. Worth having a plumber put a hole in this wall?? If not, I can absolutely live with it! Thanks as always for any advice. You folks are the best!!!
