R-Co
I have a 10-year-old Crane toilet that recently started leaking. I determined the leak was coming from the bolts that hold the tank to the bowl, which had corroded. I drained the tank, removed the bolts and the tank to bowl gasket, bought new bolts and gasket, but when I try to put it back together, the tank doesn't sit in the hole correctly. The first gasket I got didn't cover the hex ring that sits under the tank and holds the flapper/tube assembly in place. So I've gone through two other gaskets that fit over the hex ring just fine, but the tank sits above the hole to the bowl, perched on the gasket, and wobbles quite a bit. I've tried bolting it down as much as I dare but it still wobbles because it's not "seated" quite right in the hole. I've tried adding spacer washers to the bolts between the tank and bowl to stabilize it but it still wobbles. The gasket I have now was labeled as being for a Crane toilet, and while it fits over the tube and hex ring, it still seems too bulky for the tank to fit into the hole properly. The tank used to fit just fine. The old gasket has deteriorated enough that I don't think I should use it again. I've spent a week on this thing and I'm at a loss as to why it doesn't fit. Any advice would be appreciated. Thanks.
