Taco 5000 mixing valve - check valves built in?
Fritz57
Active Member
Oct 19, 2015
25
we have a 15yo Taco 5000 mixing valve. I can't get into Taco site for some reason. Does this valve have checks built in?
JG plumbing
Mar 26, 2021
1,388
477
Iowa
The 5000 series does. I belive they are on hot and cold side, so two actually. I don't know about a15 year old one.
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,800
565
Boston, Massachusetts
I just looked it up it doesn't say it does....or doesn't what's your issue
Fritz57
Active Member
Oct 19, 2015
25
the mix valve is used to fill 2 turtle tanks in the house. the valve is off the H/C that feeds the washer. wondering if I should have a check on both lines, if it turns out the 5000 doesn't. there is currently 1 on the Cold.
Fritz57
Active Member
Oct 19, 2015
25
thanks for that JG. that would seem to indicate that there is no internal checks.
JG plumbing
Mar 26, 2021
1,388
477
Iowa
I think it indicates there are internal check valves. How could they be fouled if they didn't exist?
Fritz57
Active Member
Oct 19, 2015
25
spoke with Taco. 5000 that is 15 years old did not have check valves built in. And the sign of a great plumber who did the install, just put a check valve on cold when Taco tech advised both hot and cold. Oh well.
