I've been asked to fix a problem with a tub that was installed 2 years ago. Customer cannot make contact with installer. I've made it clear that I MAY be able to help, but my work is certainly after the fact.
Okay, a Sterling acrylic tub (with surround) was installed in a 1st floor bath. At first glance, all looks pretty good. Everything is solid, no leaks, drains well, etc.
The problem is with the support of the tub. The tub appears to be a pretty decent model from Sterling (not as flimsy as many tubs are) but when you stand in the tub (whilst taking a shower, for example) there is a slight creaking when you walk about. It's not severe, and the problem may be somewhat psychological as much as structural.
They certainly don't want me to tear out the tub or anything, so here was a thought I had...
The basement has an unfinished ceiling and I can get to the subfloor directly under the tub w/o difficulty. Can I (carefully!) drill a few 3/4" or 1" holes and spray some kind of closed-cell foam to seal the space? Of course, I'm concerned with expansion, but I was thinking that I would spray over several visits to allow the foam to expand and dry before doing more. Also, I thought if it was a low-expanding foam it would help.
Thoughts on this method? Any other way to fix this?
