Supply line material
Farmskis
Sep 15, 2022
20
Wells, ME
Hello from Maine,
I am hooking in a retention tank. What material can I use. The line from the well is the black poly that connects via barbed fittings. I would like to connect to this and run to the tank. PVC would be simple but I don’t think it is allowed. Cpvc is allowed but I can’t find anything over 3/4 locally. I can find pex at 1” which could work. If that is my option, how do I connect the black to the pex? Do the pex barbed fittings work?
Thank you!
If you can buy a piece of 1 inch 100psi black poly just use that to the tank, then use pex on the other side. We have been using black poly for 75 years without a problem.
Hello from Maine,
Thank you!
Make your life easy and use pex for all of it.
