thecaptain0220
Hey guys, I could really use some advice on a few things. I have some questions about installing a new sump pump. Long story short, I was going to just install a backup pump, but realized my main pump needed replaced too when I started.
Depth is a big question for me. When I moved in I replaced the pump and the previous installer had the pump sitting on two blocks stacked on top of each other. The depth of the sump is 17.5" and the top of the inlet pipe is at about 6". There seems to be some sediment on the bottom of the sump pit, but I cant see to the bottom. Do I dare set the new pump on the bottom? The top of the main pump sits at 12", it would be very submerged. I also dont want it sucking up everything on the bottom. Will the water just flow back in to refill it up to the intlet?
Is it fine for the pumps to be fully submerged? When I realized my main pump needed to be replaced, I purchased a Barracuda main / backup combo. The thing I find weird about it is that the backup and main pump are installed at the same level. This means that the backup pump will pretty much always be submerged. If you look at the picture on the box it shows that it is supposed to be this way, but their diagram shows them offset.
The main pump sits 12" tall and the float switch is set to 11". The backup pump is 8" tall and its switch is set to 13.5". This means the backup pump will spend most of the time fully submerged. Is this ok?
They dont mention a 1 way check valve in the installation for this kit. I assume that one will need to be used? The previous installer had the check valve installed at the top of the pipe, about 4' off the ground. This meant that when the pump stopped all that water went back into the sump. Should the check valve be right after the pump instead?
Finally the reason my main pump died so fast, in my opinion, is that the water softener is backwashing into the sump and the pump is then sitting in very salty water for a long time. Here is a picture of the main pump when I pulled it out.
My filter is backwashing directly into the pipe. Do you think that I could connect the softener this way?
