JoeBob9000
I have a house with a deep sump pit, the challenge is the deep pit and high output. When the sump runs, it syphons all the water right back in to the pit. (See attached drawing)
Key issues:
Key issues:
- Trigger for pump is above the weeping tile inlet,
- difficult to lower the base of the pit due to it's depth
- Syphon created after cycle, backflow refills the pit
- If I put in a check valve I run the risk of burst due to freezing (northern Canadian climate)
