My hot water tank T&P valve broke and water started leaking. I called a local plumber. He replaced T&P valve and said it is a good practice to replace PRV too. My PRV is only 2 years old. But I went ahead and changed it also.
All looked ok for 2 weeks. Then I started noticing high water pressure during random times in random faucets. like Few times in kitchen faucet and few times in bathroom faucet. So attached water pressure test gauge to my outdoor water outlet. This outlet is connected to the line after the PRV. The pressure showed 50 PSI both red and black needle. I let it sit and next day i see the black stayed at 50 but the red moved to 140. That means at sometime the water pressure increased to 140 . I am not sure what is causing this issue. I am attaching the pics.
Anyone help me with the diagonoses? I called the plumber he said all looks fine. But my mind keeps worrying about this sudden increase in water pressure and what happens if there is a water pipe burst.
