mikenh
We noticed this in all the showers and a faucet so far,
All of a sudden pressure drops off to the point of releasing the diverter and the water just trickles out of the faucet, then the water pump kicks in and pressure resumes again.
The first time this happened, it wasn't enough to trip the diverter valve. Now every shower drops pressure enough to trip the valve until pressure rises and we can resume shower. The pressure drops so low that it truly is barely coming out of the faucet until the pump kicks on again in about a couple seconds.
This has been going on for about 3 days now, slightly worsening each day.
Weird but we used to complain because it seemed like the pump was always running (we have a small tank, a Well-X-Trol WX-202), and it would kick on several times during a 10-15 minute shower, now the pump seems to only kick in once during that time and the pump runs longer now until it turns off.
I recall checking it a year or two ago and the pressure on/off settings were correct as I recall. I checked the tank and pump today in operation. I missed it when it turned on, but it stopped at about 62 lbs.
The installation guide suggests the following: "... Release or add air as necessary to make the precharge pressure 2 psig below the pressure switch pump cut-in setting. (Example, if you have a WX-202-XL with a precharge of 38 psig, and you have a pressure switch setting of 30/50 psig, adjust precharge of your WX-202-XL from 38 psig to 28 psig.)..."
Again, the pressure drops rapidly, all of a sudden, then the pump kicks on.
Any help would be greatly appreciated.
Thanks
Thanks
