There is no data supporting any problems from a CSV, only inaccurate opinions from dishonest persons. The truth is the CSV was blacklisted as a disruptive product by several of the major well pump manufacturers in 1994 because it makes pumps last longer and uses smaller pressure tanks. You would think they would welcome something that makes pumps last longer, but you would be wrong. Planned obsolescence is the main design criteria for submersible pumps, and anything that makes them last longer is not wanted by the manufacturers.
You are also wrong about running a pump continuously. They are made to run 24/7/365 and say "duty" "cont" for continuous right on the side of any motor. I have one that hasn't turned off since 1999 since I installed it to pump water into a stock tank. It is the number of starts that limits the life of a pump. They are completely frictionless after fluid gets moving a short time after start up. Cooling the motor is one of the problems from cycling. Cooling flow is only present when the pump is running. It takes quite a while for the motor to cool down after it stops, and starting again too soon while the motor is still warm is not a good thing. Letting it have time to cool all the way down to water temp before starting also cause major changes in motor temp from cold to hot over and over, which is not as good as running continuously at low flow and low amps where the motor stays at a constant and cool running temperature.
It is good that you got 20 years from your pump instead of cycling it to death in 20 days or months as many of them are. But it doesn't matter how long it last, it would last several times longer if it was controlled by a Cycle Stop Valve. It is hard for an electrical engineer to understand because pumps are counter intuitive and engineers think everything should be intuitive, and this is not.
