Strange situation with new home shower...
Discussion in 'General Plumbing Help' started by mamacotti, Jan 14, 2019.
  1. Jan 14, 2019 #1
    mamacotti
    mamacotti
    mamacotti
    Jan 14, 2019
    Texas
    Hi everyone. I'm new to this forum and I sure hope someone can help me with this. We've bought a new home, and it has several tankless electric water heaters. The one for the master bath works fine for the shower, and this what I'm asking about today. Our shower is a tiled walk-in with a ceiling mount shower head. The faucet control is a single handle Delta 1400 Series. AND THEN...there is a tub spout with a diverter stem 9" off the floor. This makes no sense to me. What could be the reason? Bucket filler? Foot Washer? I would love to have a handheld shower put in place of the tub spout, but what do I do about the diverter? It would certainly come in handy for washing dogs, etc. Some have said it's just a matter of having a plumber replacing the rough-in with one that will divert. I have no problem with that, but I was able to take a peak behind the faucet trim, and can't imagine how it could be changed without the tile having to be torn out and replaced? Any thoughts?
  2. Jan 15, 2019 #2
    wood4d
    wood4d
    wood4d
    Apr 1, 2014
    97
    14
    They used a tub/shower valve instead of a shower valve. We do that on outdoor showers here so we can winterize them. To have a hand shower you need a different setup. Who knows why they did it but you cant change it without rear access to the plumbing.
  3. Jan 15, 2019 #3
    Rickyman
    Rickyman
    Rickyman
    Feb 5, 2018
    112
    41
    It’s a toe test for temperature. You turn on the valve, put your foot in the water coming out the spout, when it’s the right temperature you pull the diverter and take a shower. That way you don’t get blasted by cold water if you were to step in the shower and turn on the valve with water only coming out the shower head.
    Mikey likes this.
  4. Jan 16, 2019 #4
    mamacotti
    mamacotti
    mamacotti
    Jan 14, 2019
    Texas
    OK. Thanks so much for taking the time to read and answer! I appreciate it!
  5. Jan 16, 2019 #5
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,312
    yes, a shower valve can be switched out with out ripping out the tile
    you have to do it from the room behind the shower
    a bedroom wall, closet, hallway...Sheetrock is easier to patch than tile
    or.....
    install a chrome elbow where the existing spout is
    install a 3' long chrome 1/2'' pipe, with chrome stand off brackets
    use the pipe as a hand held slide as seen in this picture
    with water connection on the stand pipe with diverter knob
    Zanne likes this.
  6. Jan 17, 2019 #6
    Mikey
    Mikey
    Mikey
    Well-Known Member Supporting Member
    Jul 16, 2018
    233
    37
    Northwest Washington
    To amplify what Rickyman said, I just built a new shower and didn't put in the tub spout, and regret it deeply. But if you truly want to get rid of it, just take off the spout, cap off the supply line (if you're lucky it goes back to a drop-eared ell which can be plugged) and repair the hole in the wall (you're on your own here).
  7. Feb 11, 2019 #7
    mamacotti
    mamacotti
    mamacotti
    Jan 14, 2019
    Texas
    Frodo! YES!!! That is exactly what I want to do, except I need the elbow to have a diverter on it, as the tub spout does! I haven't found one yet, and I wasn't even sure it's possible to replace the tub spout with anything?
    As far as tearing out from behind...ugh. That would mean going in the wall from the outside, and the exterior walls of this house are thick, styrofoam forms filled with concrete.
    Also, keep in mind the shower head comes out of the ceiling. I wish I knew how to post pics here...
  8. Feb 11, 2019 #8
    Mikey
    Mikey
    Mikey
    Jul 16, 2018
    233
    37
    I think a substantial amount of water will be diverted to the old shower with this scheme, though, so the old shower will dribble all the time. But you could put a shower shutoff valve in that line to address that:
    [​IMG]
  9. Feb 11, 2019 #9
    Mikey
    Mikey
    Mikey
    Jul 16, 2018
    233
    37
  10. Feb 12, 2019 #10
    mamacotti
    mamacotti
    mamacotti
    Jan 14, 2019
    Texas
    Thanks, Mikey! So, just to clarify... it IS okay to put an elbow on in place of the tub spout. And just as an extra piece add a diverter before the handheld shower? That (kinda) seems simple enough!
    Part of my concern is that someone told me that with the electric tankless heater, you HAVE to have a tub spout w/diverter because it serves as a......I forget...vacuum breaker, maybe? And for whatever reason that is a necessary part. I'm sorry, I'm not a plumber. So I don't see why your recommendation wouldn't serve the same purpose?
Share This Page
