Solution found for water pump cycling
Vanlifenomad
Dec 28, 2020
Calgary
Hello everyone :)
So here is my plumbing setup for my camper van conversion. I decided to go with one of those smaller faucets you use to fill water bottles in order to use less water. My issue is that the faucet requires a 1/4 inch inner diameter tubing hooked up to it but as you can see the tubing going into the water pump is much larger. When I turn the pump on and open the tap, the smaller tubing just flails around and leaks, probably due to all the pressure going into the small tube.
My question: Should I run the same diameter of tubing on the outflow and get a barb to reduce the diameter at the faucet? Or will this cause pressure issues as well?
Thank you so so much for any insight. And Happy Holidays :)
Oli
Jeff Handy
Jul 5, 2019
3,887
1,093
Chicago suburbs
Can you put a speed control (basically a dimmer) on the power wires, so it pumps with less force?
Ask the manufacturer if they sell that, or if one is compatible.
Maybe there is a digital version that might be kinder to the motor.
You can also buy better tubing than the clear vinyl stuff you have on there.
Vanlifenomad
Dec 28, 2020
Calgary
Thanks Jeff, I'll look into this :)
Vanlifenomad
Dec 28, 2020
Calgary
Turns out these Flojet pumps have a pressure plate you can remove with a phillips head. Once removed, there is a screw that you can tighten clockwise while running the tap. I tightened it almost all the way and the cycling stopped completely. The water flow is consistent now!
RS
Dec 25, 2019
161
48
USA
I assume the pump has a pressure control switch, so it shuts off when it reaches about 50 psi? First of all, you need to replace the discharge line with something more substantial. Then, I would recommend installing a small pressure thank so the pump doesn't cycle on and off so often. We had a small camper that we used off the grid and the pump would start/stop 10 times while I brushed my teeth. I installed a small pressure tank, (about 2 quarts) and then it would only start twice. Whatever you have room for!
