joeunc
Just recently, replaced old fill valve, flapper and water supply line. The fill valve is Korky Platinum Universal.
The valve with its rubber gasket sits in hole, I hand tighten the outside black washer as tight as possible,,I have even added and extra turn with wrench..it' seems super tight.
Place a small bowl under it, see about 5 or 6 drips in it an hour. I can look on the underside and I can see slow seep from where the black washer is connected to bottom of tank.
Everything is new,,any ideas or do i just go get a different fill valve tomorrow to try? if so which one?
toilet is an American Standard
thanks
thanks
