Sink won't drain without disposal running
Discussion in 'General Plumbing Help' started by krotz, Mar 15, 2018.
  1. Mar 15, 2018 #1
    krotz
    krotz
    krotz
    Mar 15, 2018
    I have searched all over the internet for help with this, but all of the solutions are to do things I've either already done or are not issues with my set-up.
    We recently bought a home in which the kitchen sink does not drain unless the disposal is running. The sink also fills with the wastewater from the dishwasher when that is running.
    The two most common causes of this problem, according to the internet, are that the wall drain is higher than the disposal drain, or that the dishwasher drain hose has not been attached to the underside of the counter or to the wall. However, as you will see in the pictures I have attached, neither of these is the case for me.
    I cannot imagine that the drain is clogged, as it works when the disposal is on.
    What am I missing? Thank you!
  2. Mar 15, 2018 #2
    ExtraMilePlumbing
    ExtraMilePlumbing
    ExtraMilePlumbing
    Aug 21, 2014
    438
    68
    Snake the drain, sounds like you have a congested drain line,disassemble you’re drain line and snake it,also add a clean out while u redo the drain
  3. Mar 15, 2018 #3
    ExtraMilePlumbing
    ExtraMilePlumbing
    ExtraMilePlumbing
    Aug 21, 2014
    438
    68
    As for the dishwasher add an air gap or do the irc air gap code
  4. Mar 15, 2018 #4
    krotz
    krotz
    krotz
    Mar 15, 2018
    Thank you ExtraMilePlumbing ... the one thing I don't understand is how can the drain line be congested if it works with the disposal on? Wouldn't it be congested then as well?
  5. Mar 15, 2018 #5
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    568
    76
    Boston, Massachusetts
    because the disposal is forcing the water down the first poster is right snake the drain you should also raise the dishwasher dishcharge line loop as high as possible
    krotz and SHR like this.
  6. Mar 17, 2018 #6
    SHR
    SHR
    SHR
    Member Professional
    Mar 5, 2014
    630
    291
    , Minnesota
    Simple, basic drain line clog. Snake it or hire someone with a jetter to clear the line.
Share This Page
