dca
Hello - I had an old Delta crystal ball style shower faucet/valve replaced with a Pfister Rancho by a local independent plumber.
This is in a 2nd bath that is back to back with the master bath. Seemed like he did a decent job, but now when the 2nd bath shower is in use, and the toilet is flushed in the master bath, the pipes in the wall oscillate until the toilet valve shuts off. It may also happen to a lesser extent when both showers are in use.
I'm attaching pictures - can someone advise if the plumber did anything suspect, or if it is a function of only the Pfister mixing valve itself + pressure drop. I assume the Pfister has to be causing the oscillation, just not sure why a drop in pressure triggers it.
I see where the middle pipe is shimmed in a haphazard way. Maybe if I dampen the other pipes, it may minimize the sound, but not a true fix.
I called Pfister and their LCC support of course said it couldn't be the valve and had to be the house (but it didn't do this before). I asked if I could send them pictures, just to verify that part was done properly to their installation expectations, and they said No. Great customer support these days!
So, please advise and thank you in advance!
DCA
DCA
