Rafterman
Hello all. My wife and I live in the coastal area of southeast North Carolina, about a mile from the Intracoastal Waterway. We moved into our new house in February of last year. It has a poured concrete raised slab foundation. We have county water, with a private company managing the sewage for our area. Since about the middle of last summer, we've had a smell occasionally coming from our master bathroom shower drain, which is located on the ground floor. It's not a raw sewage smell, but almost like "sewage light" if you get what I mean. It's not a "rotten egg" sulfur smell either. The shower is a standard 5-foot size with a fiberglass pan in the bottom and tile walls. The smell only comes from the shower drain after you've been in there with the water running for about 5-7 minutes, but then it will stay until about 5-10 minutes after you're done showering. The smell does not occur every time we take a shower though, which is quite puzzling and frustrating. Sometimes we can shower for days without the smell, but then it'll come back. After coming back, it'll smell during every shower for anywhere from a day to a week before going way again. Sometimes the smell is light and sometimes it's so heavy it'll knock you over. The smell is 100% coming from the shower drain itself, and is not being brought into the bathroom via the HVAC system.
We had the plumbing company that worked on our house do a smoke test last September and it was negative. None of our p-traps were dry, including the one for the shower in question. The plumber and I looked all over the house for the sight or smell of smoke, including in the attic, and found nothing. Unfortunately, we were not able to replicate the smell for the plumber at that time (of course.) He said that with a negative smoke test, there was nothing else he could do and left.
Fast-forward to February of this year, and we had the builder's warranty guy come out to fix some other minor issues before we hit our one year mark in the house. We mentioned to him that the shower smell was still present, yet sporadic. He contacted the plumbing company again, who came out and did another smoke test just this morning, which was negative. The plumber said that there was nothing he could do moving forward since the smoke test was negative, and would have the owner of the company reach out to us to discuss any other potential options.
An internet search for "shower drain smell" returned tons of possibilities and solutions. Some articles said the smell was produced by bacteria that feed on the shampoo and soap residue in your pipes. Others said the smell could be due to a dry trap somewhere in the house (again, ours are all wet.) Even others said the smell could be from a toilet somewhere in the house, with the gases coming through our shower drain. However, how could this happen without a dry p-trap? We've tried pretty much every solution we could find, and poured it down the shower drain, including Liquid Drano, vinegar with baking soda, and pure boiling water. NOTHING we've tried has worked. We tried using different shampoo and body wash since they're all made with varying chemicals. Didn't work. The longest we were able to make the smell go away was a little over two weeks before it came back again. I even climbed up on our roof to check the vents up there since one article said that birds or debris could get stuck in the vent pipe and cause the smell, but all the vents were clear.
My wife was literally in tears this morning as the plumber told us there was nothing more he could do since the smoke test was negative. I asked him with the builder paying for all this, why don't they tear up our shower pan for a closer look? He said he can't even be sure that's where the source of the smell is.
This is our pre-retirement home that we plan to live in for at least the next 15-20 years. We can not and will not live with a shower smell for the next two decades. There MUST be some logical explanation for this, but we are at our wit's end and losing hope. If you, or someone you know has ever experienced and/or more importantly fixed a problem like this, PLEASE share what happened and how it was remedied. We are desperate. Please help us solve the problem no one can seem to fix!
