BostonDIYer
Hello,
New to this forum and looking for someone who can give some advice on how to best handle muly current plumbing conundrum.
I had to recently demo a shower because I was dumb enough to donate thousands of dollars to a couple of knuckleheads who sold me a 2-year tiled shower. It's a 2-year shower because it leaks into your second floor ceiling after 1-year and then you learn it's actually the failed waterproofing that caused it so you tear it out in year 2!
So, I am progressing along swimmingly and am fixing all sorts of crap they should have caught/done themselves. I am officially into the subfloor and therefore have to replace the shower drain. I am struggling to figure out what the heck exactly to do with this thing.
Let me start by saying the previous drain was not a problem. Also, excuse my poor cutting job. That was my first attempt at using an inside pipe cutter. Anyway, the plumbing seemed to do it's job just fine previously. But, the house and plumbing are coming up on 20 years old and while I am in here, I may as well update whatever needs updating.
That said, I also came across what appears to be a small piece of cpvc (maybe?) connected to what I believe is just plain old PVC. I did not know there were different types of PVC until about 5 minutes ago but I did learn the cement for cpvc needs to be different.
Here are my questions...
I would like this drain to remain roughly exactly where it was previously. This is my first time working with PVC but put 10 years in the trades so I know how to get by. Given the importance of this step, I want to get this exactly right. What would the preferred path forward be with what I have going on in this picture? FWIW, everything past the p-trap seems to be sloped correctly, venting in the right place, etc. What should I do to get a well performing drain back in place so I can begin closing up the subfloor?
Next and maybe a very noob question but why no primer on most of these other connections? Were the plumbers actually that neat or should I be able to crack these joints open with a couple or wrenches? Sounds funny as I type it but the joints do look a bit like they could be mechanically connected and not cemented.
Last question, in the picture with the two pipes coupled together, when I wrap my hand around that and give it a slight wiggle, it feels as though the coupling has a little bit of play in it. The water stains below it I don't *believe* are from this drain pipe and are instead from the non-waterproof shower curb that was there previously. However, it feels like this connection could be more solid than it actually is. Should I cut it out and splice in a fresh piece with new primer and cement?
P.s. you all can ignore the pex for now. I am probably going to clean that up a bit as well since they also failed to add pressure balance loops for the body jets. Good time for me to get rid of some of these mostly unnecessarily buried fittings.
Thanks in advance!
-- Chris
Thanks in advance!
-- Chris
