Need-Help-In-FL
Hello Everyone,
Unfortunately, I can't figure out what to do with my shower stall (no tub) drain. Can someone please help me? I removed the pop-in drain cover (metal) to clean it. After removing the drain cover grate (metal), I noticed that the seal between the 2" down-pipe (has purple PVC glue shown on it) and the piece above was failing. You can see in my image that the old clear PVC glue seal between the down-pipe and the portion above was flaking off (yellow seal pics). My shower pan isn't leaking (that I'm aware of). My home is 6 years old and this shower is on the second floor. Thank you very much for your assistance with this, I greatly appreciate it!
Do I need to install one of the black rubber seals (I found someone online who had one that appears to slip into the space I have in the drain flange above the drain pipe and will sit flush against the drain pipe? Or do I need to install something like this: https://www.amazon.com/gp/product/B000BO4RVI/ref=ox_sc_saved_image_1?smid=ATVPDKIKX0DER&psc=1. If so, do you use purple PVC glue to connect the bottom of that part to the top of the 2" drain pipe?
Should I also replace the drain pan flange or no (if it's not leaking)? I read a post on here and he said you can remove it with this tool: https://www.amazon.com/gp/product/B00IG42488/ref=ox_sc_saved_image_2?smid=ATVPDKIKX0DER&psc=1.
