PumpThatSump
I have a difficult toilet install with a 8 inch rough-in. I can't move the flange forward because of a beam that's in the way and can't get an offset flange in there. I can't move the wall any further back.
I have a BRIGGS toilet bowl (10 inch rough-in) that will fit over the flange, but the tank will not install after installing the bowl. Are there offset adapters for the TANK that would work or, better yet, does someone make a narrow (front to back) tank that would install on the BRIGGS bowl that has a 2 inch flush valve opening?
Another solution would be to find a tank that could be installed on the wall. Does anybody make something like that? Then I would need something that would attach to the tank and to the bowl to route the water. Where would I find a pipe like that?
Any suggestions?
Any suggestions?
