JohnnyD
I’m getting just 4-5 years out of my residential (irrigation) well pump. I have changed out 4 of them over the years. It is used just to water my lawn from May – September (Boston area), run 2 to 3 times per week. Current situation – Pump does not run, control box overload trips after ~20 seconds. I have swapped the Control Box with a new one that I have – same results. Voltage readings are in spec. Using a DVM and a VOM the resistance readings for the primary and starting windings are within specs. Wirings-to-ground are around 40K ohms. The expansion tank air pressure was in specs at the end of the last watering season. I do not recall excessive cycling of the pump when the irrigation system was on. Well is ~420’ deep in mostly ledge. Though I hoped my problem is above ground my assumption is that my motor is toast again.
Given the depth of the well and the labor to pull it up each time, I have replaced the motors and pumps together. Each time the motor leads appear fried where they enter the motor housing. I do not believe we are in an excessive lightning area (possible reason for the motor leads frying?).
Specs - 1.5hp Gould 10GS15412CL pump with CentriPro M154120-01 Motor. 220V single phase. Well-X-Trol WX250 tank. Franklin and CentriPro Control boxes.
Current guesstimate for replacing the pump and motor in my area is $2.2K – $2.5K. I had pulled the pump once by hand (with help) but nicked a wire which prompts me to let the pros do what they do. I would like to put in a 10+ year solution. Would folks have ideas on why I am going through motors so often and what I can do to have a longer-term solution?
Thank you
Thank you
