Wellwellwell
Hi, all-
The booster pump that pressurizes my pressure tanks is short cycling.
This first happened a few weeks ago. I drained both tanks, filled them, drained them again, filled them & the short cycling issue was fixed.
Until this afternoon. I had to leave, so I turned the pump off, left it until I got home, when it was dark & chilly.
I spent about 30 minutes messing with things and figured out 2 things that I hope will get me started on troubleshooting this issue:
1. Tank 1 (on the left) is not draining. After opening the spigot & letting things drain until there is no flow, but the tank is still full. Or at least so heavy I cannot rock it. I'm guessing it has a ruptured membrane & needs to be replaced.
2. Tank 2 (on the right) is not filling with water. I set the pressure on this tank a few weeks ago when I first looked at this issue. At that time I added a few pounds of air (with the tank empty) to bring it to 47PSI (pressure switch comes on at 50PSI). But tonight I noticed that with the system pressurized, this tank is empty. I can rock it slightly after the booster pump pressurizes the system.
When I first looked at this a few weeks ago all I did was drain the tanks, add a little air & things started working normally again. I assumed I had some silt or other debris in my pressure switch & running all the water flushed it out.
Now I'm wondering if it's possible that some of the membrane from Tank 1 could be blocking Tank 2?
Is this possible? Or do ruptured membranes just split & otherwise stay in place?
I replaced the pressure switch 2 years ago, so I'd be surprised if that had failed.
The tanks, though, are almost 20 years old, so I wouldn't be surprised to have a failure there.
A few weeks ago I was able to drain Tank 1 by pressurizing the tank through the Schrader valve on top of the tank. Could that have shredded the membrane? I wasn't in a hurry to drain the tank & I gave it an occasional burst of air to help things along, although I think I had the air hose set to about 130 PSI.
I don't understand why Tank 2 isn't working, though.
Love to hear your .02!
Best,
Chris
Best,
Chris
