Hi Folks.
Helping out elder couple. Friends. They have ~20-25 year old Shallow well pump in their crawlspace. The pump is Grundfos JP-7 3/4 HP There seem to be minor leak going on. Corrosion is everywhere. It could be that connection is leaky and drips into the housing. Connection is definitely an issue too and has to be re-piped.
I have somebody who can re-pipe it and replace pump. I want to have the pump on hand, so if it needs to be replaced, I have one on hand.
Including images of tag from the pump installed.
I am thinking of this one for replacement:
https://www.amazon.com/RainBro-Cast-Shallow-Model-CSW075/dp/B088K5R6H1
I know its not top of the line, but will it work as replacement?
Kindly let me know.
Thank you.
Mike.
Kindly let me know.
Thank you.
Mike.
