Few weeks ago I had a tenant go crazy with 'flushable wipes' and clog the sewer lateral. 3 hours with the drain snake I pulled out a half dozen wipes and then yelled at them. but from there everything was working good. This week - new clog. I came back with the snake - didnt hit any wipes but got out about 40 feet and hit a hard stop with the self feeder. I tried auto feed snake on that spot for 30 minutes and either there is bend/elbow/trap that snake cant navigate or something hard is stuck in pipe.
40' puts me right about the front of the house. There is no cleanout there. There is an air vent at front of house inside basement - it comes about 2 feet elbow through brike wall and goes out the front. Clog seems to be on street side of the air vent as water does back up in to air vent. I dont think air vent is 'on top of' the main sewer I think is next to it. I saw this because the first elbow off the air vent is toward the back of the house. ie it elbows toward the back of house and guessing then it elbows around 180 degrees to wye into the laterial two feet or so away.
Would you take any other steps after snaking for 30 minutes before busting concrete and digging a hole. I cant easily camera it from the laterial cleanout I have access to since pipe is drains so slow it is mostly filled with water. My plan right now is to dig where I think the laterial is near frot of house and cut it open. Plan B might be to go get the camera again and use it blind with the tracer to see if I can confirm laterial path but I feel I know where it is. I kind of feel like the concereted over the sewer lateral house trap. I assume even 100 years ago they had house trap with a cleanout?
Any other advice? If I try a drain bladder I would likely need to use two as I have two laterial branches - one from main stack and one from roof drain. That might be a hell mary if the issue is regular clog on street side of house trap.
