tomanderson312
I just purchased a house 2 weeks ago and the sewage pump that is for the basement bathroom has stopped working:
1. It's a 1/3 hp Stevens model S7000 (can't find that this is made anymore)
2. The lift is 11 feet
3. The 2" pipe out of the pump has a check valve installed
4. The pump turns on for maybe 2 seconds (just enough to pump water up the pipe several feet) and then shuts off. About 30 seconds later it does the same thing....over and over.
Before I go to the expense of a new pump: Could the problem be the check valve? If I do purchase a new pump, should I go with a 1/2 hp for that much lift?
