D dannac Member Joined Jan 13, 2022 Messages 10 Reaction score 1 Location USA Jan 13, 2022 #1 Water tank drain. Would like to setup with standard 3/4" for hose. Could someone help with parts needed please. Please see attached image. Attachments TankDrain.jpg 294.6 KB · Views: 12
CT18 professional Professional Supporting Member Joined Apr 30, 2014 Messages 1,352 Reaction score 544 Location Bloomfield Hills, Michigan Jan 13, 2022 #2 If it were mine I would use a 2" M.I.P adapter and then bush down to 3/4" with a ball valve and hose adapter. Probably PVC down to 3/4" and then solder the rest. Drill a hole in the cap and then needle nose to pull it out
D dannac Member Joined Jan 13, 2022 Messages 10 Reaction score 1 Location USA Jan 13, 2022 #3 Thanks for the reply. Not familiar with plumbing parts terminology. Attached image of PVC fitting, is this what you are referring to. Though it does not have a female threaded end. Trying to keep the faucet distance from tank as short as possible. Attachments 2to3_4.jpg 45.6 KB · Views: 2
D dannac Member Joined Jan 13, 2022 Messages 10 Reaction score 1 Location USA Jan 13, 2022 #4 Just noticed the "common plumbing terms" thread at the top of the forum. M.I.P. is a iron pipe adapter. Found this on Amazon ... would this work ? Attachments 2to3_4SS.jpg 78 KB · Views: 6
breplum Professional Professional Joined Nov 14, 2017 Messages 2,358 Reaction score 1,198 Location Lafayette, CA Jan 15, 2022 #5 Yes, should work. You need a biggish wrench and joint compound.
A arctic bill Well-Known Member Joined Dec 24, 2020 Messages 592 Reaction score 233 Location montreal Jan 15, 2022 #6 do not over tighten ,
D dannac Member Joined Jan 13, 2022 Messages 10 Reaction score 1 Location USA Jan 16, 2022 #7 Thanks breplum & artic bill. Joint compound ... is that some type of paste ? Is teflon tape needed ?
T Twowaxhack Currently in the Lab conducting research Professional Joined Feb 9, 2021 Messages 14,036 Reaction score 6,558 Location United states Jan 16, 2022 #8 dannac said: Thanks breplum & artic bill. Joint compound ... is that some type of paste ? Is teflon tape needed ? Click to expand... Joint compound is for drywall..... Plumbers use pipe dope J/k it’s the same. I would just use pipe dope on the threads.
M MicEd69 Well-Known Member Supporting Member Joined Dec 4, 2021 Messages 1,789 Reaction score 657 Location Missouri Jan 16, 2022 #9 Twowaxhack said: Joint compound is for drywall..... Plumbers use pipe dope✌ J/k it’s the same. I would just use pipe dope on the threads. Click to expand...
D dannac Member Joined Jan 13, 2022 Messages 10 Reaction score 1 Location USA Jan 17, 2022 #10 Ok ... thanks Twowaxhack & MicEd69
