Florida house, circa 1979, not out in the sticks, in a neighbourhood with hundreds of other houses of similar age and presumably similar designs.
Last few years the tank has not seemed to drain well, tank itself has been checked and seems in great condition (no roots, holes, etc). Ok, so maybe the drain field is failing... I dig up the outlet side, the pipe goes down a foot or two, then... nothing. It doesn't connect to anything. It seems that around an inch under the pipe is a hard gravel layer.
I'm expecting this pipe to go to further pipes, or a distribution box that then goes to further pipes but so far I haven't found any other pipes (initial thought was I'd dug into the top of a distribution box that had failed, but no evidence of this).
Is the water really meant to drain into this gravel layer? And nothing else? I can't find any info on this kind of design. (Though until a few years back it _was_ working fine - with 3-4 years between pump outs).
