quefol
hello I recently purchased a lake lot with a concrete septic tank. I discovered the top concrete riser section protruding from the ground has shifted and is now leaking ground water. What I need to do is lift it, reapply sealant and realign it. The riser I need to lift has no anchor points. How would someone be able to lift it? And what do I use for a sealant?
Thanks
Thanks
