jreist
I am having problems with my septic tank. The tank is 3 yrs old and there is just me and my wife living in a log home in New Brunswick. The tank is backing up into the tub.
The intake pipe is under water and thought I had a problem with the feild. Looking at the outlet pipe, I found it above the water. I used a board to feel down the sides of the baffles and could not find obstructions or the spot on the baffle for water flow.
I checked the water levels, intake 4" middle 3", outlet 3" below the inside. The inlet baffle is 8"X8" and seams to go down to the bottom.
I took a empty coffee container and scooped out the water at the outlet end and took 10 - 5 gal pails and pored them out 100 ft into the woods. This brought the water level down so it was intake 7" middle 6", outlet 5" below the inside. So it seems to be flowing through the baffles. How far would I have to bring it down so I could see the openings between the baffles.
The next question I have to ask is whether the tank was put in backwards? The inlet pipe is 5" below the inside while the outlet is only 1" below, should it be reversed? I put the level on the top and the inlet side is higher but the inlet pipe was below the water while the outlet was above the water.
