Septic System Failed And Passed Inspection?
Doobie
Jan 26, 2021
Your Basement
Hey, we are in the process of trying to buy a home. It is using a septic system and there is no option to connect to a sewer at least not anytime soon. First Inspection company comes out and tests the system and says this " Recent attempts of repairs have been made, effluent levels in the distribution box are high, unable to dye test for this reason. Contact a licensed septic repair person and or the county health department for necessary repairs to this system. " They then fail the system on the inspection and say it is in an unacceptable operating condition.
I then call the company who did the most recent work on it and this what they did in November of 2020: Rehab of the septic system. Including Excavation, labor, materials. Jetted all leach lines. Pumped tank and leach field. Installed vents and clean-outs. Replaced baffle in outflow line of the tank. Installed two new riser assemblies. Replaced distribution box. Rough backfill to allow for proper ground settling.
Now what seems odd to me, is if you do this much work on a system and it still fails? I got in contact with the company that did this work and we met out at the property. He then said everything is fine and in working order and not to worry about the distribution box being high as the Water table is pretty high right now(Been high since 1/25 and still high today as of 1/26. (We have had some snow melting and light rain here and there. He did not dye test and says those can actually do more harm than good, he then said "All a dye test does is tell you where it's going not if the system is good or not. Now I've been doing some research and it seems no matter what, if the distribution box is high, that would mean the system has failed and is unable to properly drain into the field. The guy who originally did the work seemed honest and put his best foot forward, but still, the system fails on paper. Are we going to have to do this when we sell the house, I feel like that a failure would turn most buyers away. Can anyone shine some light on this, really not sure what to believe.
Thanks
DIY_guy
Jan 17, 2021
9
22202
Something is not right, get another opinion, is the seller paying for the inspections?
FishScreener
Aug 23, 2018
502
170
83467
Call your state Department of Environmental Quality or whatever it is called where you are.
It shouldn’t be backing up into your distribution box.
And, I’d recommend talking to a Professional Engineer familiar with septic systems. It might cast a couple of hundred bucks, but they are going to give you the straight scoop, on the condition of the system, and any remediation required.
plowking
Dec 22, 2020
18
03290
I agree with the other comments. It is easier to check systems with vents by taking top of vent off if it is not glued down and look inside with light. I do that on fields when I clean the septic tank l .Empty vent is good, a vent full of water bad. Open dist. box like your inspection did is better. Depends on what state you are in. Some states require a certificate like Title 5 program in Ma. from seller to give to buyer showing system has passed a inspection by certified inspector.
Twowaxhack
Professional
Professional
Feb 9, 2021
1,902
716
United states
Sounds like a failing drain field.
Here that means another perc test and engineered system based off those perc results.Relocate the drain field or a built up mound system......or both !
$10-14K
But that’s what we do, not necessarily what you need.
