- Joined
- Jul 1, 2023
- Messages
- 29
- Reaction score
- 16
I'm planning on renovating an existing shower space (4 x 6 feet) which currently has the following devices:
On a side note, retaining the Moen shower valve is imperative, it's been uber reliable and does not have water flow restrictions, nor do the existing Speakman shower heads.
Matching the trim for the new proposed diverter and transfer valves is somewhat desirable, however an impossibility with the "chop suey" mix of devices, existing and new.
Comments, suggestions or guffaws anyone?
- vintage (late '80's) Moen "Moentrol" shower/tub fixture, non pressure balanced nor temperature controlled
- (2) Speakman old school shower heads, one fixed, the other handheld, both have individual inline isolation valves.
- Delta pulldown style tub diverter spout.
- 1/2" copper plumbing throughout, water pressure regulator set @ 70 psi.
- retaining the Moen shower valve
- retaining both Speakman shower heads, but removing their isolation valves.
- replacing the Delta tub spout with a non-diverter Moen unit (it was free)
- adding an in-wall diverter valve for the Moen spout
- adding (2) body sprays, either Moen or Delta units
- adding an in-wall transfer valve, again either a Moen or Delta 4 port unit
- tub spout only
- shower head 1 only
- shower head 2 only
- both shower heads simultaneously
- both shower heads and both body sprays all at once
