pasadena_commut
I ran across a video for a device called a "sediment buster" on youtube today:
Basically it is a Y. The common leg screws onto a water heater drain valve, one arm has a ball valve and then attaches to a hose to drain the water, and the other arm has what looks like a common car tire valve. The body of the device is clear. Whenever the drain isn't passing sediment or even water, which is easily seen because of the clear body, some air is pushed through the tire valve with a tire pump or a compressor and then sediment/water starts coming through again.
As far as I can tell all this device does is blow some bubbles back through the tank drain valve, which jiggles around the sediment clogging it (either at the valve or the inlet at the tank), and lets more material pass - until it jams up again. No way it is doing more than that since once the air gets inside the tank proper it is going to bubble straight up to the top, which will do exactly nothing to move sediment around far away on the bottom. In the video around 4:45 one can see the drain valve on the tank. It turns 90 degrees to open or close, which would suggest it is a ball valve, but it seems to be quite prone to jamming, which suggests it is not full port and so constricts the flow. If anybody is familiar with that particular valve, please chime in with a description of it.
At first glance this device seems to be analogous to a piece of wire shoved back up the drain, but in a more convenient form. With a wire one has to keep putting the drain hose on and off, whereas here it can stay on. The thing I like best about it is the clear body. I have done something similar to this with a brass Y with a ball valve in each arm, and one arm attached to a hose from outside. This would back flush (powerfully) and stir up the sediment not just at the valve but over a pretty large area. Since one cannot see through brass I had to keep running outside to see what was coming out. If there was a similar Y to the one I used, but in clear plastic it would work much like the sediment buster, but probably better, since a big slug of water will stir up the bottom over a large area, whereas a small stream of air will only stir things locally.
