mikeh85
I've been to a couple of local plumbing supply houses, none have been able to ID this shutoff trim/outlet box. I took this photo in a friend's house under construction 3 months ago, and I am looking for the same type of trim to use when I replace my main shutoff valve.
Looks like it was provided blank and the plumber drilled the holes in the ends for the pipe. The only answer I seem to get from the supply houses is "buy a washer outlet box and remove the valves." That seems like a waste, if the product I need is made and available.
Anyone know who makes this or what I should be searching for?
Thank you!
-Michael
Thank you!
-Michael
