S-trap too low to fit bin underneath
Damo
Oct 15, 2018
Australia
Hello,
I'm trying to install a bin under the sink so I need to either raise the s-trap about 6cm or move it about 6 inches to the right.
Can someone please recommend me the easiest way to do this? My problem is that I need a fitting for my dishwasher waste as well. I have looked at flexible hoses and short s-traps but none of those have a connection for the dishwasher waste.
I have room to go horizontal, just not vertical. Is there a p-trap or other handy connection I could use?
Looks like an "S" trap to me. Which direction does that drain line go at the bottom. Also, secure that dishwasher drain line high on the underside of that cabinet.
your problem is some one brought the pipe up thru the floor directly under the bowl of the sink
you need
a combination, a cleanout
a elbow
a 2x1.5x1.5 tee
a p trap
and a 1 .5 '' air admitance valve
what are those plastic hoes you have in the picture?
if it is a dishwasher hose. it needs to loop up, to the bottom of the counter top
tie off. [use a sink clip,to tie to] then to the y branch tail piece
