Reverse Osmosis
larbec
Active Member
Feb 4, 2011
26
Dallas, Texas
MY reverse osmosis system under my kitchen sink started to run slowly. Could my filters cause this issue. I've not changed them in two Years
It's a 5 stage Proline Plus system
Dirty filters can cause low water pressure ,other things can cause low pressure also ( low tank pressure,faucet out of adjustment). The filters should be replaced yearly -- I would replaced the filter first
I checked the tank pressure. It was "0". I hooked up my air compressor and put 7lbs in it and it's running better than ever.
My confusion is the tank felt heavy at "0" lbs and like it had water in it. Is this normal? Is my tank bad?
