Toodle
I bought a house built in 1997. I was going to replace the water filter and I got confused. There is a red gate valve on the input side of the water filter. There is a blue gate valve on the output side of the valve. The output side then feeds water to the hot water heater and into the house, assuming cold water feed.
It seems I would just turn off the red valve; go turn on cold water to drain water from the pipes; turn off blue valve; push down pressure release on the filter housing to release remaining pressure; then replace the filter. But when I turn the red valve off it leaks a pretty steady drip. Then when I go let the water run it never stops. I closed the blue valve anyway. When I press the pressure valve on the water filter housing water streams out and does not stop. I have only left it pressed for about 20 seconds but it does not slow down at all.
I am wondering if the red gate valve is not working? It stops the dripping when I open it back up which seems to indicate the valve is stopping water... not sure?
So... how can I test this? More importantly, how could I turn the water off to my house if I had to? I guess the blue valve would do that? I don’t completely understand the pipes coming into the house. There are two. Both are larger than the normal house pipes. One has a gate valve and then goes into the pressure tank. The other one has a ball valve that is closed. It meets up with the pipe off the pressure tank at a T and then the T goes on to the red gate valve before the water filter ( the one that leaks when it’s open). Not sure what this second line in that is turned off is.
Can I change the filter some other way?
How do I test this valve?
What is the second line coming into the house but not going to 5be pressure tank for?
If I turn off the water at the gate valve coming into the house before the pressure tank, will that turn off water to the house immediately or does the tank have to drain before water stops running? If so, seems like that’s not a good emergency shut off?
Appreciate any advice on figuring this out.
