Replacing radiator panels
roman-bytes
May 9, 2024
new york city
I’m looking to replace the panels on the front of my radiator. How do people usually do this? I’m trying to save money, so I was thinking of ordering some custom-size perforated metal sheets and drilling them to the front. Is that a decent idea, or is there a better way?
Salvage yard? Maybe ask a professional in your area to see if they know where to find a set of used panels?
If you look carefully at that front louvered panel, @roman-bytes you'll note the louvers are designed to flow air IN the bottom set, and OUT the top set, kind of very slow convection air flow.
If I am not mistaken, however, those are not part of the radiator (I could be wrong!) but are part of a radiator COVER. In areas with these old systems (radiators in NYC typically were steam) there were plenty of firms selling radiator covers. I used to live in NY and there were ads for them all the time in the papers so people could cover up an old ugly radiator like this:
and instead make it look like this:
If you just go to any search engine, type in "radiator cover" or "steam radiator cover" and go to images you'll find a whole selection of great ideas you could create yourself. Believe it or not, Amazon also has a ton of them for sale. Just search for radiator covers.
  • Like
Reactions: Moz
Thanks havasu and Mitchell for the detailed info!
To update the thread, what I ended up doing was ordering a pack of 4 pre-sized 36" x 24" perforated aluminum metal sheets from Amazon for $70, and cutting them into the size I needed using a pair of $15 tin snips. I then inserted them into the same slots that the previous radiator panels sat in. It was easy and quick, and I am more than happy with the results.
The only changes I might make is painting them at some point and affixing them to each other and/or the radiator casing, so there are fewer seams.
