user 32496
- Joined
- Sep 21, 2023
- Messages
- 112
- Reaction score
- 79
So...I have to replace my 19 year old electric water heater ASAP since it started leaking yesterday. I can't believe it only lasted 19 years! The old one is a Bradford White 50gal, 4500 kWh heater with a serial number starting with B. Bradford White says that indicates a 2005 model.
It currently doesn't have an expansion tank so I need to add one. I've heard all kinds of things about the position requirements for the expansion tank so I thought I'd put it out here for expert advise. I have checked the installation instructions on two different expansion tanks and they show a picture of the tank installed with the water on top and the air on the bottom but the Zurn model says this:
INSTALLATION
5. Strapping or bracing must be used when tank is installed in the horizontal position. This will allow support of the tank when filled with water.
So, does it matter what the orientation of the tank is?
Also, the current setup has cpvc attached directly to the input and output of the heater. I seem to remember hearing that an 18" metal piping is required between the water heater and plastic pipe however I don't see that in the IPC code. Chapter 5 simply says:
SECTION 503
CONNECTIONS
503.1 Cold water line valve. The cold water branch line
from the main water supply line to each hot water storage
tank or water heater shall be provided with a valve, located
near the equipment and serving only the hot water storage
tank or water heater.
I found this picture on-line where the installer just tee'd right out of the heater and installed the expansion tank upside-down right on top. Is that acceptable?
Here's the current setup...
INSTALLATION
SECTION 503
CONNECTIONS
