I'm wanting to replace the shower trim. Right now, the shower has a Moen standard valve. I want to avoid replacing the valve. I know that will limit my options some. I can either replace it with a standard trim kit or a Moentrol trim kit if I get this adapter http://www.moen.com/replacement-parts/part?part=REPLACEMENT:145058
I've already removed the old trim. Now I'm left with what is in the pictures. The valve seems to be loose. I can pull on it and it will moved forward until the plastic piece hit the back of the shower wall. If I push on it it will go into the wall a couple of inches. Is this normal? What will keep it from moving when the new trim is installed?
When I use the adapter, will I have to cut a bigger hole in the shower? Right now there is a hole about 2.5". Do I remove the plastic piece before putting the adapter on?
Thank you for your time and help.
